Anyone with AN fuel lines?
Old Jun 10, 2003 | 11:41 AM
PatriotTA's Avatar
I am really thinking about doing an AN fuel line setup. Does anyone here have AN fittings with braided lines? I'd like to see some pics to get some ideas.
Old Jun 10, 2003 | 12:27 PM
Brady's Avatar
Arrow here's mine
http://turbocharged.net/twinturbo/Installation11
Old Jun 10, 2003 | 01:48 PM
No pics, except for a couple of the fittings...
In tank Bosch pump with 6AN discharge
Outboard (parallel) Bosch pump with 10AN suction from tank sump, 6AN discharge.
Dual 6AN into a single 6AN using an NOS "Y" fitting
Single 6AN to SX billet filter in stock location
Single 6AN to front of car
Single to dual 6AN split with "Y" fitting, into 6AN fitting welded to the back end of each fuel rail
Single 6AN return line, from a fitting welded to the diagonal cross-over pipe.
6AN to a Weldon AFPR under the cowl, and then returning to tank.
System will support 1000HP.
Return line
Weldon AFPR, dual 6AN inlets to back of rails
Outboard pump and filter
Pressure sensor tap on fuel rail
Old Jun 10, 2003 | 02:41 PM
PatriotTA's Avatar
Thanks for the pics, guys. I had seen yours before, Brady, it looks nice.
Old Jun 10, 2003 | 03:18 PM
Townsd's Avatar
Wow! That is an awesome web site. I must have read it and looked at pictures for 3 hours. When you brought out the BFH I was cracking up laughing. I too have used the BGH effectively heh heh. That is just an amazing setup. I am green with envy.
Old Jun 10, 2003 | 08:15 PM
slopokrodrigez's Avatar
Just finished the complete system with out of tank pump and lines and so on. What are you looking for. Practical advice? what to watch out for? what you have to buy? I'll post pictures if you tell me how to
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
