Anyone else feel that K&N filters are a waste of money?
Old Feb 17, 2005 | 05:43 AM
  #16
rskrause's Avatar
Moderator
Re: Anyone else feel that K&N filters are a waste of money?
Obviously, it depends what you are comparing it to, but David Vizard (extremely credible guy for those who don't know of him) has dyno and bench tested the K&N and found it measurably superior to stock filters.
Rich
Old Feb 17, 2005 | 09:42 AM
  #17
bdc95ta's Avatar
in which book rskrause I'm almost done reading "How to Build Horsepower" and haven't come across that test yet.
guys check out bobistheoilguy.com good website but like any message board don't believe most of what you read.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
edit:
your right rkrause on pg. 72 he talks about the K&N Stub Stack on two-barrel holley showing no less than 13 hp gains on a street-stock 350. The further I read the more I see your right he does recomend K&N as his first choice showing typical rwhp improvements from 1-5%. In order to see these gains the cars had to be retuned to optimize performance though.
-b
Old Feb 17, 2005 | 10:38 AM
  #18
BadCo.'s Avatar
Originally Posted by bluemaggot
Are you sure the demo isn't remote controlled and that they have a guy watching it who turns the air pressure up when you put the K&N filter on there?! And are you sure the K&N guys didn't know that you had changed the filter and then rigged the clock at the track to make it look like the K&N filter is better?!
the moon could have been in a synchronous orbit with jupiter at that precise moment therefore causing a stronger gravitational pull on the demo machine's ball!
Old Feb 17, 2005 | 11:01 AM
  #19
mitchntx's Avatar
I toasted a MAF with a K&N.
Apparently from over-oiling the filter.
I'm telling you, that filter was a light, light pink ... it doesn't take much ...
Old Feb 17, 2005 | 11:25 AM
  #20
bdc95ta's Avatar
very good pt. mitchntx I believe there was a service annocment on that from the dealership a couple of years ago.
Husbarn
Mar 30, 2015 11:45 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jan 23, 2015 01:13 PM
