Anybody heard of this?
Old Feb 24, 2013 | 04:15 PM
shaunmotyka's Avatar
•1 Erson E110026 Performance Camshaft Hyd. (.445"/.465" Lift 214*/224* @.05 Duration 112 l/c)
•1 Set PBM HA817 Hyd. Lifters
•1 Set PBM 3000 Hyd. Valve springs ( 1.250" O.D. 110# @ 1.700" 300# @ 1.250" up to .500" lift)
•1 Set PBM 501S Chrome Moly Retainers
Old Feb 24, 2013 | 06:58 PM
RamAir95TA's Avatar
Re: Anybody heard of this?
What are you asking? How are we supposed to know?!?
Old Feb 24, 2013 | 08:46 PM
sorry got into a hurry when typing..
erson cams? cant find much of anything online about them. was wondering if anybody has.
Old Feb 24, 2013 | 09:15 PM
Erson cams came about in the early '60s. The founder (Sig Erson RIP 2009) used to work for Isky (founder Ed Iskendarian).
Old Feb 25, 2013 | 12:04 AM
Would appear to part of this package:
SB Chevy 355 Performance Master Engine Kit w Pistons | eBay
Part No. E110026-K
Street Fighter cams offers great power increase over stock cams, some suited for nitrous. Engine mods will enhance performance. Fair idle, good low to mid-range torque and HP. Work with stock or modified engines. Can use stock rear gears, manual or auto trans.
Lifters have proper crown on bottom of lifter face and proper preload of .004-.006 @ operating temperature.
RPM Range 1000 - 5500
Duration @ .050 Lift 214 / 224 deg int/exh
Valve Lift .443 in / .465 in int/exh
Lobe Separation 112 deg
Old# 140108
Complete with Lifters and Assembly Lube
Old Feb 25, 2013 | 09:35 AM
cnorton's Avatar
Just in case anyone is considering this package for an LT1, be advised that the statement: "Lifters have proper crown on bottom of lifter face and proper preload of .004-.006 @ operating temperature..." is a reference to a flat hydraulic tappet configuration. Not really optimum for a roller cam LT1 application.
c
Old Feb 26, 2013 | 05:11 AM
c
What I "quoted" was the spec that I found on one of the links, and has a "K" suffix. Since the question did not include the K suffix, and since the cam is listed as hydraulic, the quote may be misleading.
It does appear that the package on ebay is for a Gen 1 SBC, not an LT1. That would seem to indicate the cam nose may not match the LT1 requirements, although that can be corrected.
Old Feb 26, 2013 | 06:59 PM
KW Baraka's Avatar
I've never seen or heard of a Gen-2 (LT1/LT4) Erson cam.
In my experience, they are strictly Gen-1.
KW
Old Feb 27, 2013 | 10:00 AM
I think the fact that no one is responding who has actually used an Erson cam in an LT1 is confirming that.
Old Feb 28, 2013 | 02:27 PM
Bersaglieri's Avatar
Erson does grind LT1 camshafts, they actually used to be highly coveted, but they were only done on a custom case by case basis. I'm yet to find a standard line up of LT1 grinds from them, that, combined with a lack of supporting information [lobe catalog/adv numbers, ICL, etc] and a poor website, keeps me from considering anything from them. I suggest staying away from Erson for LT1 stuff.
Comp Cams has some decent shelf grinds but I'd point toward Lunati for the best LT1 shelf grinds to date, more specifically the Voodoo line. If you want the most out of a camshaft you need to look custom like Lloyd Elliott, Advanced Inductions, Bullet, etc. But be prepared to supply them with all the information about your setup. Static compression, gearing, weight, head info, quench, stall speed, everything.
No offense shaun, but you need to consider doing more reading and less posting until your closer to knowing what your wanting, needing, and capable of.
autoxr166
Sep 25, 2015 04:21 PM
colts0455
Sep 22, 2015 02:03 PM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
colts0455
Sep 4, 2015 01:41 PM
