Any1 buy just the MSD cap/rotor?
Old Mar 5, 2007 | 10:55 AM
Vicious95Z28's Avatar
My dist is still good and I need a cap/rotor. All of the screws in my dist broke off while removing the cap. Does the MSD cap/rotor come with new screws?
Old Mar 5, 2007 | 12:06 PM
You're sure the brearing in the back 1/2 of the Opti is still good? You're sure teh optical sensor isn't experiencing rust particle buildup from a rusting bearing retainer plate? You're sure the seal around the harness wire tower is not dried out? How about the seal between the back 1/2 and the plastic spacer/housing?
Old Mar 5, 2007 | 03:55 PM
It was running fine when I pulled it out.
Old Mar 5, 2007 | 06:09 PM
96capricemgr's Avatar
I am running the MDS cap and rotor on an opti that had 70K on it before I put that stuff on and I have put 6-7K on since, all good.
Old Mar 5, 2007 | 06:12 PM
reamo04's Avatar
i have just the cap and rotor, getting put on this weekend. It does nto come with new screws tho
Old Mar 5, 2007 | 07:15 PM
Mine did come with new screws and there was an extra with a little aluminum tab to seal the top bettwer. They were phillips too instead of the torx.
Old Mar 5, 2007 | 07:29 PM
reamo04's Avatar
idk, maybe mine did come with screws, idk, it still in the package
Old Mar 6, 2007 | 08:59 AM
morpwral's Avatar
Thumbs up
I got the MSD cap and rotor kit on my 95 T/A. Installed early last year, went on a 1300 mile round trip last Thanksgiving, so far no issues. Probably have around 6k on it since install. Right now she's in storage.
MSD kit comes with new hardware, phillips head screws for everything. As mentioned earlier, it adds an extra (5th) screw and a aluminum block for the extra mount hole (top) on the cap assembly. During your install, be extra careful not to over tightened the rotor screws, they are very small. Broke one of mine, luckily I still had my original rotor screws and used those in place of the MSD pieces, so far so good (knocking on wood).
The rest of my opti looked good, no rust seen, bearing felt solid and no play. Stock cap just went dead on the number one cylinder.
Good luck with your install if you decide on the MSD cap/rotor kit.
Allan.
Old Mar 6, 2007 | 03:54 PM
Thanx guys, That's what I needed
HarleyZ28
Oct 5, 2015 06:23 AM
transam_388
Mar 15, 2015 11:53 AM
Black93lt1
Nov 21, 2014 07:30 PM
ScottZ
Mar 3, 2004 01:34 PM
