What goes in this hole???
Old Mar 5, 2007 | 07:12 PM
wrd1972's Avatar
Larger plug just above the filter.
Old Mar 5, 2007 | 07:15 PM
mdacton's Avatar
is it just a threaded hole?
if it is then its nothing...thats where a manual clutch pivot would go on a sbc
Old Mar 5, 2007 | 07:16 PM
Another Red Z's Avatar
It looks like it is for a old school mechanical clutch . It should go straight through to the flywheel area .
Old Mar 5, 2007 | 07:19 PM
wrd1972's Avatar
Cool,
I cant remeber if there was a plug here or not, what about justa bolt?
Old Mar 5, 2007 | 07:38 PM
Nothing.
Old Mar 5, 2007 | 07:39 PM
SevenStars's Avatar
I didnt put anything there when I put my motor back together.
On a seperate note what did you need to run the oil filter w/o the cooler? I'm considering removing mine...
Old Mar 5, 2007 | 07:40 PM
mdacton's Avatar
an oil filter adapter, they have them in summit
Old Mar 5, 2007 | 08:46 PM
SevenStars's Avatar
http://store.summitracing.com/partde...5&autoview=sku
This it?
Old Mar 5, 2007 | 09:01 PM
Dave89IROC's Avatar
Originally Posted by SevenStars
yes
Old Mar 5, 2007 | 09:22 PM
wrd1972's Avatar
I just stripped my oil cooler off and used the existing adapter plate, it looks exactly like the one in the photo. I assume that this works. I had to get new bolts to replace the studs though.
If this is not the way to do it then please someone tell me.
Old Mar 5, 2007 | 09:31 PM
Dave89IROC's Avatar
it is, you are correct, it is the exact same adapter, swaping the bolts is all that is needed
Old Mar 6, 2007 | 01:39 AM
69gto96z's Avatar
What benefit does removing the oil cooler have on the motor?
Old Mar 6, 2007 | 05:38 AM
SevenStars's Avatar
Do you by chance know the size you used?
Old Mar 6, 2007 | 06:35 AM
wrd1972's Avatar
Dont remember, take the stud to the hardware store and match it up with a hardened automotive bolt. It is a common size.
Old Mar 6, 2007 | 04:10 PM
Dave89IROC's Avatar
I believe its 5/16-18 thread, 1" long maybe?
pull a stud and take it with you
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
generaldave
Sep 25, 2015 06:48 PM
4586
Jul 31, 2015 06:03 PM
Boss002
Jul 24, 2015 10:47 AM
