Any random LT1 knowledge out there?
Old May 24, 2003 | 01:59 PM
96z's Avatar
96z
Anyone have any random or useless knowledge about the LT1 from working on it so much? Oil filter number, torque spec, kind of bolt, routing of wires etc?
Since Ive been under the hood so much I know some randomestuff, for example on the starter the two bolts that hold the wires are 13mm and 8mm.
What about you guys?
Old May 24, 2003 | 02:06 PM
gb95zconv's Avatar
Heres a good one ....the stock lt1 pistons use a specific ring set that cost about $160 a set...
Old May 24, 2003 | 10:01 PM
96z's Avatar
96z
Come on you guys...some of you guys know some random stuff.
Old May 24, 2003 | 10:07 PM
Rodrigues's Avatar
The chips in the pcm are an28f512, thats pretty random
Old May 24, 2003 | 10:09 PM
ishz28's Avatar
The windshield has 48 degree rake, making it damn near impossible to see anyhting but the reflected dash board when the sun hits it dead on!
Old May 24, 2003 | 10:14 PM
JSK333's Avatar
For the panhard bar, the stupid bolt-head is 21mm, and the stupid nut is 18mm.
Why stupid? Because it snapped in half after refusing to come out with anything less than 450psi of air-wrenching mayhem.
Once out, they looked like they were from a 50 yr old car that had been sleeping in a lake!
Old May 24, 2003 | 10:24 PM
thefast1's Avatar
I keep a roll of duct tape, and 9/16-1/2-5/8-3/8 wrenches in the glove box.
Old May 24, 2003 | 11:31 PM
rskrause's Avatar
Moderator
I think the commonest fastener you have to deal with is 10mm.
Rich Krause
Old May 24, 2003 | 11:48 PM
Timberwolf's Avatar
the battery tray is integrated with the coolant overflow bottle...
Old May 24, 2003 | 11:52 PM
On the underside of the A4 console shift quadrant indicator, it shows the rear end gear code (GU2 and GU5) and the indicator markings that match it (PRNDL2 and PRND21). Overdrive (OD) is not shown.
Old May 24, 2003 | 11:59 PM
RCF925's Avatar
Inide the oil filter housing on the block is a hole for Dumbas$%^ who don't change their oil filters often enough. Your dirty oil just bypasses the filter and runs through your motor. I plugged mine forcing the oil through the filter.
Old May 25, 2003 | 12:29 AM
superal's Avatar
There is a upc sticker on top of a '93 m6 tranny.
Old May 25, 2003 | 01:29 AM
96z's Avatar
96z
this is pretty good.
Old May 25, 2003 | 02:00 AM
carlos64030's Avatar
You can push in on the left side of the firewall to have easier access to the bell-housing to motor bolts for removal.
97Z28Muscle
Feb 6, 2015 10:44 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
nophix
Nov 30, 2014 10:26 PM
JSK333
Sep 9, 2002 10:33 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
