Any info on single spec cams like 239/239
Old Feb 22, 2004 | 10:57 AM
1BadBrd's Avatar
Anything with spec like that. You always read about 230/236, 236/242, 227/233 stuff like thatbut what about same spec cams. Nu-Tek has a lot of single spec cams also does TPIS. But i don't see to many people post single spec cams on the board.
Old Feb 22, 2004 | 04:50 PM
1BadBrd's Avatar
ttt
Old Feb 22, 2004 | 07:38 PM
$hawn's Avatar
I think most people go with a dual pattern camshaft, is becuase the heads exhaust port flow isnt as much as the intake side, like I said though I think.
Old Feb 22, 2004 | 08:11 PM
rskrause's Avatar
Moderator
Typical LTx heads have relatively better intake than exhaust flow, especially when a restrictive street type exhaust system is used. So, they will make more hp with a "dual pattern" cam. This is especially true with a power adder, which substantially increases the volume of exhaust gasses. Cars with race heads and open exhausts often do best with single pattern cams, but even there many people use somewhat of a split, thpugh less than usually seen with street LTx cars.
Rich Krause
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
Elcojoe
Nov 17, 2014 10:27 PM
