Any ideas why the pushrods are scoring?
Old Sep 23, 2005 | 09:22 PM
Robs97Z28's Avatar
On the way to work one of the pushrods broke. The ball end was ripped off. I'm not sure why. They were heat tread pushrods CCA-7808-16 . I am also using comp cam mag rr 1.6 CCA-1418-16. There is scoring between the rr and the ball end of the pushrod. I'm using Isky spings D235.
Is it possible that the spring pressures are to high for this type of pushrod?
Old Sep 24, 2005 | 12:33 AM
SS RRR's Avatar
Re: Any ideas why the pushrods are scoring?
Scoring where on the rocker? Pics would help. Perhaps in the rod cup of the rocker? Reads like the valve train may be too lose.
Old Sep 24, 2005 | 09:44 AM
Robs97Z28's Avatar
the scoring was on the end of the pushrod and in the cup of the rr.
Old Sep 24, 2005 | 02:04 PM
SS RRR's Avatar
more than likely rockers are adjusted too loosely.
Old Sep 24, 2005 | 08:48 PM
Robs97Z28's Avatar
I talked a tec at Jegs. I went over my set up with him, it looks like the spring are too high for these pushrods. The spring are rated for 350 lds and closed they are 130 lds. The pushrods I was using are rated at the same 350 lds. On top of that, I am running 1.6 and not the stock 1.5 rrs. Which, is pushing the limits of these pushrods.
Old Sep 24, 2005 | 10:01 PM
Dave89IROC's Avatar
are they SA or NSA rockers? are you running guide plates? if yes, from where?
Old Sep 25, 2005 | 12:23 AM
Robs97Z28's Avatar
SA... No guide plates
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
asilomar244
Jul 12, 2015 05:53 AM
ducttape1975
Jul 10, 2015 06:29 PM
MadMav
Jun 15, 2015 09:51 PM
armedtrigger
Feb 24, 2015 08:30 PM
