Any cutoff to fuel pump through EEC system, etc.?
Old Jun 12, 2005 | 12:00 AM
BTM's Avatar
BTM
95 Z. Ran fine yesterday, today cranks but won't start as if getting no fuel. No audible fuel pump priming sound when ignition is turned on. Don't have a fuel pressure gauge but would be willing to bet there is none at all.
Question is this: is my fuel pump definitely toast, or is there a cutoff engineered into the engine management system related to 'service engine soon' light or anything else?
Also, how difficult/pain-in-the-*** is a fuel pump swap? Any firsthand stories?
Old Jun 12, 2005 | 03:40 AM
GreenDemon's Avatar
Re: Any cutoff to fuel pump through EEC system, etc.?
It's not hard to check the fuel pump circuit. You'll need a multimeter and wiring diagrams, of course. The fuel pump relay is underneath the "dead" pedal. You can check for power to and from the relay. If the relay gets power it means the pcm is not turning it on (or those wires are bad). If the fuel pump is getting power it has to be wiring, a fuse, or the pump itself. Make sure and do your diagnosis first so you don't end up wasting money. Although fuel pumps going out on LT1s isn't unusual, usually it goes out slowly. If it dies suddenly I would suspect an electrical problem. I'm pretty sure if the PCM doesn't turn the fuel pump on there's a security light that will remain illuminated.
If you do diagnose it make sure to study the diagrams carefully, some relays are ground side switched, I can't remember if the fuel pump relay is one or not.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
