Antifreeze Question???
Old Jun 1, 2005 | 02:29 PM
gamecockfan04's Avatar
So, Im in the middle of changing my Opti and when I pulled the waterpump I lost almost 2 gallons of Dexcool. My question is how much more coolant is there in it and should I try and flush it now and go with the Green stuff? If so how to flush it and how much Green kind would I need? Do I mix 1 gallon green stuff with 1 gallon distilled water? Or should I just put some of the Dexcool compatible Prestone 50/50 stuff in? My Dexcool coolant was very clean when it came out, so its really not in bad shape.
Old Jun 1, 2005 | 02:53 PM
OBE1 95Z28's Avatar
Re: Antifreeze Question???
You'll still have some in the block but I don't know how much. There are 2 drain plugs; one on the driver's side by the engine mount, the other is the knock sensor.
Old Jun 1, 2005 | 03:16 PM
Rashiki's Avatar
NOOOO green stuff. GM has a seperate coolant for a reason.
I believe total coolant capacity is 15-16 quarts or so. Use a 50/50 mixture of dex-cool and distilled water. When was the last time the system was flushed? If you can't remember, you can't go wrong doing it.
Old Jun 1, 2005 | 03:51 PM
SS MPSTR's Avatar
I flushed mine out completely and replaced it with non-Dexcool green antifreeze mixed with distilled water.
Old Jun 1, 2005 | 04:48 PM
Compstall's Avatar
I have been using the green stuff for over 5 years no problem.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
warmeck
Mar 1, 2015 08:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
