another tranny/ecm question
Old Aug 9, 2003 | 03:07 PM
Timberwolf's Avatar
What would cuase the car not to want to move in first gear yet move ok in 2nd and drive? I know it's a pcm setting, I just can't figure it out. With one program the car works like it should, with another it does what I said above. I have checked every table for difference that I can find related to transmission operation but can't find what's causing the problem. I asked in the computer tuning section, but that forum moves so slow I may never get an answer...
Old Aug 9, 2003 | 03:42 PM
Timberwolf's Avatar
ANYONE??
Old Aug 9, 2003 | 03:54 PM
Timberwolf's Avatar
here's my tunercat files. "crappy" runs bad, closed loop, but trans works as it should.
the other is open loop, but trans doesn't work right. Can you find a difference that would cause that?
www.sixtyninecamaro.com/images/pcm/
Old Aug 9, 2003 | 10:08 PM
Timberwolf's Avatar
ttt
Old Aug 9, 2003 | 10:57 PM
rage366's Avatar
well, i had a similar problem. my tranny was a 94 and i was using a 95 pcm, and it was starting out in 2nd. when i used a 94 pcm, it worked fine. hope that helps.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
