another torque spec for #134-5401 arp main studs
Old May 13, 2006 | 02:19 PM
firebirdStud's Avatar
Exclamation another torque spec for #134-5401 arp main studs
I went on arps site, and they only have the torque listed by the type of fastener, like 7/16 by whatever pitch. I have no clue what that is for my main stud kit. All I have is a part number, #134-5401. What should the nuts be tightened down to? I will be using arp molly lube too. I would like some help so I can get this sucker burning gas!! Thanks!
Cody
Old May 13, 2006 | 10:41 PM
Re: another torque spec for #134-5401 arp main studs
come on now, no one has installed these??
Old May 13, 2006 | 11:16 PM
WeirdRich's Avatar
"Torque the bolts to 75 ft lbs for arp moly assembly lubricant or torque to 90 ft lbs with 30wt motor oil."
right off the assembly sheet
although, I ended up going with Milodon main studs because surprisingly they are the only ones that make studs for their main caps....
Old May 14, 2006 | 06:44 AM
rskrause's Avatar
Moderator
Of course, you could always measure the fasteners you have and refer to the chart.
Rich
Old May 14, 2006 | 11:10 AM
lol, I dont know how to measure thread size... enlighten me! I always enjoy learning, so how would I go about doing that?? Then maybe I wouldnt have so many dumb torque threads....
MadMav
Jun 15, 2015 09:51 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
IDOXLR8
Aug 6, 2002 12:30 PM
