another question
Old Jul 20, 2007 | 10:27 PM
ROUDA's Avatar
another question
I thought I was done with the hard part in putting theses Pacesetter long tubes on. So the last thing I go to do was put the stearing back together and the wheel wont turn completely it will turn but its real tough. This sucks I want to know how you guys deal with this problem its there anyway to bend the header while its still on the car or do I have to take it back off. If the only way is to do it while its off how should I bend it.
Thanks for all the help so far.
Old Jul 21, 2007 | 12:39 AM
ROUDA's Avatar
T T T
Old Jul 21, 2007 | 05:48 AM
Guest47904's Avatar
Guest
Use a pair of channel locks to squeeze the tube in question enough to clear the shaft and move the steering shaft if need be in order to do it.
And no more TTT
Old Jul 21, 2007 | 01:02 PM
oneclean97z's Avatar
what does ttt mean anyhow?
Old Jul 21, 2007 | 01:25 PM
LT1_383's Avatar
ttt = To the Top
Is the shaft hitting the header, or does there just feel like there is resistance while turning? If the shaft is rubbing against the header, it might just be the bolt. I was able to shave the head of the steering shaft bolt down a little to get the clearance I needed.
If you just feel resistance while turning, it could be the clockspring in the column. When the shaft was off did you make sure the wheel wasn't spun?
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
