Another One Bites The Dust
Old Oct 22, 2003 | 12:10 AM
  #16
SlowAssTA's Avatar
Originally posted by S.J.S.
You did a head and cam swap with 210K on it???? damn.
well i was not aware of having 200k miles, the guy i bought the car from failed to mention the speedo was disconnected for 2 years, so i assume it was that high it has 168k miles on the odometer... so i dont know
Old Oct 22, 2003 | 12:16 AM
  #17
jonaddis84's Avatar
All you guys need to quit your whinin about spun bearings and low oil pressure
http://www.worldisround.com/articles/14895/photo12.html
That does suck though buddy.
Old Oct 22, 2003 | 12:42 AM
  #18
AlmostfastLT1's Avatar
Thanks for so information, but with the stock bottom end hold up to me stroking it.
Also, slowassta were did you get the machine work done.
Thanks alot, Mark Tisdale
Old Oct 22, 2003 | 12:45 AM
  #19
jonaddis84's Avatar
Bottom end holding up...align hone the mains/cam journals, bore/hone with deck plate, clear oil passages, clean/degrease before/after work.
If the shop does all that youll have no problem, if you want to overkill it get some splayed 4bolt caps put in, or try to find a block out of a vette with 4bolt straigt caps.
Old Oct 22, 2003 | 08:46 AM
  #20
ttt
Old Oct 22, 2003 | 12:17 PM
  #21
SlowAssTA's Avatar
i got it done at johnsons machine in norfolk
Old Oct 22, 2003 | 12:41 PM
  #22
S.J.S.'s Avatar
Damn Jonaddis.....what the hell happened to your block man. Is it just me or is that a hole in your cylinder wall???? Now thats a blow out.
Old Oct 22, 2003 | 12:48 PM
  #23
SlowAssTA's Avatar
from the looks of it, it looks like the rod went straight thru it... DAMN
Old Oct 22, 2003 | 01:45 PM
  #24
jonaddis84's Avatar
I was thinking more like the Piston and the rod went through it, it happened on a 6000+ rpm blast so one little thing broke and just tore everything up with it, I was pissed off, but sorta excited because I already knew I was getting to build a stroker.
30th Anniv Z28
Aug 1, 2015 10:39 AM
dolfan324
Jul 17, 2015 10:34 PM
Flint78
Jun 21, 2015 01:28 PM
Nellsw88
May 26, 2015 05:55 AM
IgorT.455/406
3rd Gen / L98 Engine Tech
Oct 24, 2002 05:30 PM
