Another Newb question
Old Jan 10, 2004 | 01:56 PM
Zulu-Two-Eight's Avatar
I just had my oil changed yesterday...mechanic said nothing about milky oil, water in the oil, etc... They checked the coolant, which was fine, good level, had not broked down, etc.
Car runs fine (except for IAC issue), does not smoke, burn coolant, starts on first crank, etc....
The engine doesn't overheat.
EXCEPT: today I took the oil fill cap off and there were a few drops of WATER on the inside of the cap and just inside the oil fill tube. Pulled the dipstick, which looked fine...wasn't milky or rust colored. I smelled the water, and it's definitely water...it's not slippery or sticky, does not smell like coolant, just water.
I got the car out of storage last week, it had been sitting for 6 months or so while I was overseas. It is also real cold here now (0 F)...
Please tell me this is just condensation that built up from sitting...I really haven't driven the car for more than a half hour at a time.
Old Jan 10, 2004 | 02:20 PM
FacelessZ's Avatar
Smells like water huh?
I wouldn't be worried about it at all. If anything it's just condensation...
Old Jan 10, 2004 | 02:23 PM
wannabeZo6's Avatar
i wouldnt worry, if its always on your mind just drain the oil again and get a new filter (if anything)....no worries
Old Jan 11, 2004 | 01:50 AM
Check the PCV valve.... that helps remove the condensible vapors from the crankcase.
Old Jan 11, 2004 | 05:25 AM
97WS6SCharged's Avatar
Run the car for 40 minutes or so until the valve covers get hot and then check the cap, most of the water will be gone.
Old Jan 11, 2004 | 01:32 PM
Thanks all...I can check off bug number 2 of 4...
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
