Another LT1 running problem :confused:
Old Apr 5, 2008 | 06:15 PM
  #16
bowtiekid's Avatar
Question
Ok so I took today to try and figure out what the hell is wrong. I found a cracked spark plug (#3) so I replaced that. Started it up and still ran rough. So I was checking everything one more time and after I shut the car off #1 header was still cold So I checked the injector (mechanically and electrically) and it checked out. I am using delteq and every coil is firing...
I don't know what to do... please someone any ideas...
Old Apr 5, 2008 | 06:37 PM
  #17
red 95 z28 lt1's Avatar
well check the condition of #1 plug and also see if the valves are opening for that cylinder. look under the valve cover too and crank the engine and see if the valve train for that cylinder is moving (possibly collapsed lifter, bent pushrod, broken rocker, spring etc.)
Old Apr 5, 2008 | 07:52 PM
  #18
b4cz2896's Avatar
Make sure there are no leaks between the maf and the tb. You said it started after you painted the elbow. Maybe you forgot to tighten a clamp or connect the maf pigtail.
oldschool
Feb 9, 2016 09:21 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
97SSdude
Dec 31, 2014 07:43 PM
nophix
Nov 30, 2014 10:26 PM
1LEThumper
Jul 14, 2003 12:45 PM
