another ls7 spring/lifter thread...and i did search
Old Oct 12, 2007 | 11:43 PM
Severous01's Avatar
i have a set of ls7 lifters, retainers, locks and springs.
i have a cc306 cam, small base circle
i have a 97 lt1, 383 stock heads, ported.
i know the lifters fit, now how about the springs? combo is off a 2006 ls7 vette with 3k miles on them.
Old Oct 12, 2007 | 11:45 PM
Stl94LT1's Avatar
I'm thinking the retainers/locks won't work.
Old Oct 13, 2007 | 07:37 AM
rskrause's Avatar
Moderator
"Fit" what?
Rich
Old Oct 13, 2007 | 11:07 AM
seawolf06's Avatar
They won't fit stock LT1 valves as they are meant for 8mm valves. I guess the springs are LS1 style beehives, so they might fit. There's no way for us to tell you for sure.
Old Oct 13, 2007 | 09:20 PM
Severous01's Avatar
so what do i need to make the springs work with my lt1 heads? if they're smaller valve diameters then do i just need some locks and keepers?
Old Oct 13, 2007 | 09:55 PM
speed_demon24's Avatar
Why do you want to run the LS7 springs? Chances are they aren't up to the task to control the valves with the 306...
Old Oct 16, 2007 | 08:48 PM
Severous01's Avatar
eh...they were free and they're better than the crane/comp troublesome beehives.
i'll run comp's double straight spring kit.
Old Oct 16, 2007 | 09:08 PM
dangalla's Avatar
you could get the pac 1218 or 1518
Old Oct 16, 2007 | 09:14 PM
Crane and comp beehives are made by different manufacturers.
Old Oct 17, 2007 | 08:49 AM
Vicious95Z28's Avatar
Free isn't really free if they can't control the valve and it starts bouncing off of the piston tops.
Old Oct 18, 2007 | 07:45 PM
Severous01's Avatar
they're both outsourced to mexico and other low quality steel contries.
i'll just get a matched set. i'm going with jegs lt1 kit...it's 160 and they'll work with my application. that or i'll get the lt4 hotcam spring kit.
Old Oct 18, 2007 | 07:53 PM
Stl94LT1's Avatar
The Hot Cam spring set (LT4) will not work with your CC306 camshaft.
Old Oct 18, 2007 | 07:58 PM
Um they are both made in America. Pac makes the crane springs and associated springs makes the comp beehives. And good luck running the lt4 springs on the 306....
Mikes 1994 z28
Oct 10, 2015 07:55 AM
autoxr166
Sep 25, 2015 04:21 PM
alliance12364
Sep 17, 2015 08:43 AM
Fatdog2
Sep 16, 2015 11:04 PM
Sep 11, 2015 09:44 AM
