horrible miss under 2.5k
Old Oct 12, 2007 | 06:28 PM
dangalla's Avatar
just started when i left work today, started the car and let it idle for a few minutes like usual, when i started to pull away it started to miss real bad
no codes, checked wires for arcing and burns and they looked ok
its like flipping a switch as soon as it gets to 24-2500 it clears right up and runs perfect. does not do it at idle or very light load (just like an ignition miss) but i never seen an ignition miss go away like that. anyone have any ideas here, or seen this before
thanks in advance for any responses
Old Oct 12, 2007 | 09:26 PM
chief455's Avatar
mine started doing that - and got progressively worse and expanded to more rpm ranges. Still, when cold, it would be crisp and rev nice - until driving.
I just pulled the plugs - 6 were all fouled, and installed a Delteq. I guess my opti may have been crapping out and fouling the plugs?
It runs mint again with just new plugs - and the Delteq.
Old Oct 13, 2007 | 10:56 AM
mrmint69's Avatar
The opti from all i have been reading is the most obivious thing it could be. How many miles on the one in there? If like mine it has 100K+ might be worth a shot since it will go out sooner than later.
Old Oct 13, 2007 | 11:30 AM
dangalla's Avatar
yeah it has 120k on it, but i dont understand how if it was the opti it would just go away after 2.5k
Old Oct 13, 2007 | 11:53 AM
chief455's Avatar
It's just a distribuor, cap and rotor with wear. They can do strange things - or just fail all together.
It may develop into more problems as mine did if you keep driving.
Old Oct 13, 2007 | 02:30 PM
96z28t56's Avatar
I had the same thing happen to my car, turns out a new egr valve and some seafoam was the fix.
Old Oct 13, 2007 | 04:48 PM
dangalla's Avatar
i dont have a egr and everything in my motor is nice clean and new but thanks for the reply
Old Oct 13, 2007 | 07:26 PM
dangalla's Avatar
ok i am not sure about this but it kinda sounds like i am getting really bad spark knock when it is missing
Old Oct 13, 2007 | 10:16 PM
mrmint69's Avatar
With a laptop and a cable you can see if it is having knock.
Old Oct 14, 2007 | 03:09 AM
96LT1TX's Avatar
Scan it to make sure all sensors are reading correctly. I had a pinched wire to the MAP sensor, and it wouldnt rev past 2500rpms period. Not exactly same problem but similar I guess. You could push past the "blip" if you revved hard, but it didnt seem to run good uptop that time. HTH
Old Oct 18, 2007 | 05:36 PM
dangalla's Avatar
it only seems to have this problem when it gets hot
Old Oct 18, 2007 | 08:08 PM
mlc's Avatar
mlc
I just went through the exact same thing. Started all at one time. Finally got it on a scope and saw something wrong with cyl 5. pulled the opti and there was obvious arcing beween 5 and the coil post. New opti and runs like new. All I really needed was the cap & rotor but I replaced the whole thing for insurance.
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
