GM Double Roller ??
GM Double Roller ??
Does GM make a double roller timing chain and sprokets for a 1995 LT1?
I am building a 383 stroker and would just as soon use a GM.
If not who make the best with easiest install?
Anyone got a Timing cover part number?
Jim
Jim
The 95 LT1 timing cover is PN 12552426.
GM doesn't actually make their timing sets, Cloyes does. The PN should be 9-3145.
You will need to clearance the timing cover for the roller chain to fit. It's pretty easy if you've got a paddle wheel handy.
