Another 847 record....
Old Oct 4, 2004 | 10:47 PM
atljar's Avatar
Whelp i started off with the highest stock heads dyno awhile ago at 357.
Few weeks ago, another guy, also with 847 on here did 358 or 359?
Anyways, our car club had a dyno day on saturday. 1997 m6 SS, full bolt on plus 847 put down 360.67.
The 847 on stock heads is looking like a consistent winner I want to go back to a 10 bolt and dyno again
Old Oct 4, 2004 | 10:51 PM
madwolf's Avatar
Re: Another 847 record....
You don't have to go to an 847 to get to 360 RWHP in an M6.
But, I'd have to agree.... good numbers!
Old Oct 4, 2004 | 10:52 PM
DarkHorse's Avatar
Impressive indeed. They're pretty good with AI heads too. My buddy Grease put down 412 I believe with AI heads and bolt ons - M6 car.
Old Oct 4, 2004 | 10:55 PM
atljar's Avatar
Ion you dont count, you tune these things for a living. I know you really fed that baby cam of yours some 110 leaded and cranked up the timing tables jk jk. You made high 340s (?) or something in a4 with a baby cam. Nothing wrong about that. You get that thing leaving well at the track and i dont want to mess with it.
Old Oct 4, 2004 | 11:00 PM
madwolf's Avatar
Baby cam....
Actually, I wasn't necessarily talking about mine... It's definetely a nice cam, but I'm sure you can do it with a 230/236 also.... A custom cam would be even better.
Beleive it or not, I've had several customers with a 306 or 847 requesting the rev limiter set at 6200. Question...why do you go to such a big cam in the first place if you don't plan to rev it high? That's why there are smaller cams out there that will do a pretty good job only at lower rpms.
Old Oct 4, 2004 | 11:17 PM
atljar's Avatar
Ya my buddy made mid 330s in an a4 car with 230/236 on a 110. Im sure with an m6 it would have been 350ish too.
As for the rev limiter question, i have NO idea, but it doesnt suprise me one bit. My car doesnt have a rev limiter, nor has it for a longtime. It always just got in the way of what i was trying to do, lol. The 847 in my car peaked at about 6100, but was tabletop flat above 350 rwhp from 5500-6600ish. If you arent using that wide powerband, then you are losing every point of getting a bigger cam. 100% agree with you, go smaller and go faster if you arent going to rev.
Old Oct 4, 2004 | 11:33 PM
'94 Bad A Z28's Avatar
I'm hoping for 380ish with my set of heads that I got and the 847... with BBK shorties ... and I have no problem reving my car high... when I get it dyno tuned I'll rev it till power drops off, and then just set shifts a few 100 RPMs lower than that.
Old Oct 4, 2004 | 11:35 PM
By few I mean 200... hehe...
Old Oct 5, 2004 | 01:22 AM
Jon A's Avatar
Well, from what I've seen the smaller cams only really beat the bigger (good) ones down at "drivablility RPM's" when set up right. Altjar makes more power at 4500 RPM than almost all of the "baby cam" dynos I've seen. So unless they're going to be shifting well below 6K or so (why bother with a cam in the first place then?)....
But yeah, they are wasting much of the cam's potential. However, just because they're doing that doesn't mean they'd be faster using all of the (lesser) potential of a smaller cam.
Old Oct 5, 2004 | 02:03 AM
S8ER95Z's Avatar
Whats a good point to be revving a 306 Madwolf?? You set these up all the time.. any ideas?
Old Oct 5, 2004 | 07:44 AM
madwolf's Avatar
In an auto with 3.42s, I would shift at 6600, but I normally set the shift points ~6400.
Old Oct 5, 2004 | 10:04 AM
Type_O_Negative_1320's Avatar
Here's his dyno graph. Not too shabby for a cam only car.
http://lt1dave.com/media/dyno_day_20041002/don_best.gif
Old Oct 5, 2004 | 10:14 AM
IllusionalTA's Avatar
I can't wait to see what my cam only LT1 is gonna dyno.. It should be up there..
Old Oct 5, 2004 | 10:22 AM
gm cam 234/242
Old Oct 5, 2004 | 10:26 AM
atljar's Avatar
Its a GM production cam, Crane also makes a version in their powerMax series.
234/242 on a 112lsa, 107icl, 575/595 lift with 1.6
