Another 847 record....
Old Oct 13, 2004 | 03:04 PM
  #61
S8ER95Z's Avatar
Re: Another 847 record....
I was down for 11 months after spinning bearings
Spin it to 6700rpm you guys say.. .uh... hmm..maybe not.
Old Oct 13, 2004 | 07:53 PM
  #62
SStrokerAce's Avatar
Spun bearings is a oil pressure problem or something got into the motor during a cam swap and caused it.
Only problems from high RPM are when you over do the rod bolts and then you don't have to worry about the bearings cause the rod will take care of the block for you.
That's the bad thing about a stock LT1 bottom end vs. a stock LS1, at least a LS1 can drop new ARP rod bolts in there where you can't do that easily on a LT1 because you have to resize the big ends of the rods and at that point Scat I beams are a better choice.
Bret
Old Oct 13, 2004 | 07:54 PM
  #63
Originally Posted by JamesC94LT1
360rwhp with stock heads and the 847 cam is awesome! I am running basically identical custom cam in my setup and Love the way it pulls!
Been turning the stock bottom end 6800-7000. Right now I have a serious lean condition so I am waiting on a walbro pump to take it back to the dyno. I recently put down 386.9rwhp at close to a 14.0 A/F ratio. I think its got 410ish in it once I can get it more fuel!
Way 2 Go guys! Those numbers with stock heads are very impressive!
You gotta richen that thing up some before those stock pistons have a hole in them!
Bret
Old Oct 14, 2004 | 02:17 AM
  #64
shady93z's Avatar
who has the fastest CAM ONLY LT1 on here?
Old Oct 14, 2004 | 02:19 AM
  #65
atljar's Avatar
AFAIK, i have the fastest 6 speed.
Frank (forget user name) has the fastest cam only car overall. Its got a baby cam in it (210/224) and last i saw went 11.40s. Car is lightweight, and he gets some awesome launches.
Old Oct 14, 2004 | 02:37 AM
  #66
ShawnMacAnanny's Avatar
That all depends. There is a guy on here with bolt ons and a cam dynoing around 267rwhp running like 12.4's. Then there are people with heavy mods dynoing 340+ rwhp who can't even break into the 12's.
Old Oct 14, 2004 | 12:28 PM
  #67
shady93z's Avatar
i'm talking about quarter mile times. dyno numbers don't mean much to me. my car only put down 317 rwhp and went 11.90. and still have some more weight reduction to do .
Old Oct 14, 2004 | 03:14 PM
  #68
92rslt1's Avatar
i have an off the wall question. im rebuiling mine right now. i decided a wanted to go to the cc306 and spin higher rpms on a rebuilt stock bottom. im to the point of re assembling it. i have .002 oil clearance on my mains and im concerned about spinning one. im pretty sure thats fine for a street car but im not sure about all those extra revs. whats a good crank oil clearance to have on a cam like the 847 or a 306?
nice vidoes and links theres some crazy dyno #s in there.
Old Oct 14, 2004 | 08:22 PM
  #69
.002 is perfect main bearing clearance.
Cams don't change the main bearing clearance.
Bret
Old Oct 14, 2004 | 09:27 PM
  #70
92rslt1's Avatar
Bret
yea i know lol. i just wanted to be sure it wasnt too lose or too tight for higher revs.
Old Nov 2, 2004 | 01:25 AM
  #71
unTAmedLS1's Avatar
I did 350/350 on my 224/230 112 lsa on stock heads and only bolton was headers and cai....no throttle body or anything like that oh and that was with 11 degrees of false knock from a bad sensor
Old Nov 2, 2004 | 01:43 AM
  #72
Jon A's Avatar
Could you post your dyno chart? I'd be really interested in the rest of the curve, etc.
Old Nov 2, 2004 | 01:47 AM
  #73
atljar's Avatar
Talking to me or untamedls1?
Old Nov 2, 2004 | 02:17 AM
  #74
unTAmedLS1's Avatar
If hes talking to me unfortunetly I dont have it but I promise it was legit I have no reason to lie I just cant find where the hell it went too my peak hp was at 5950 and it held it to 6200 tq was at about 2800 I think or somewhere around there
Old Nov 2, 2004 | 05:28 AM
  #75
Jon A's Avatar
I've seen yours, silly.
