Aluminum or steel crankshaft hub.
Old Mar 20, 2010 | 12:09 AM
LT1 POWR's Avatar
Is one preferred over the other? I figure aluminum has less rotating mass, but isn't as strong. What about a "big block" hub? I'm looking to get an ATI dampner. This is going on a street TC78 383.
Also as for the balancer material should I get aluminum or aluminum/steel.
Old Mar 20, 2010 | 07:15 AM
I wouldn't worry about mass on a piece that is so close to the centerline of the crank.
Old Mar 20, 2010 | 09:16 PM
LT1 POWR's Avatar
They say the aluminum piece cannot be honed. Will that be a problem? I'm using a 24x ignition system and might need to shave off a little to get all the pulleys lined up with the dampner.
Should I worry about the aluminum hub not being as strong as the steel hub in regards to the keyway?
Old Mar 20, 2010 | 09:38 PM
MikeGyver's Avatar
I see no reason to go with the aluminum one, I would go with the steel hub.
Old Mar 21, 2010 | 10:34 AM
rskrause's Avatar
Moderator
Steel.
Rich
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
4586
Jul 31, 2015 06:03 PM
