Alternator voltage question
Old Jul 1, 2006 | 10:28 AM
hey01's Avatar
what kind of voltage should i see coming out of my alt? Im thinking mine is a little low.
the max it is putting out is 13.0 - 13.1 @ 2000+ rpms
Old Jul 1, 2006 | 10:33 AM
n2ceptor's Avatar
Re: Alternator voltage question
Normal output is around 13.8~14.2 volts at idle..... But if battery is weak, it might be alittle higher...
If lower, check connections first, before thinking the alt is bad..
Old Jul 1, 2006 | 10:36 AM
hey01's Avatar
Battery is only a year 1/2 at most old........but that doesn't mean anything
the alt was removed and reinstalled when i did my plugs so im sure all the connections are good.
the car runs fine I just had free scan hooked up to i lastnight and noticed my voltage was really low, yes i have a UD pulley but 2000 should be WELL beyond full charge RPMS
Old Jul 2, 2006 | 08:42 AM
hey01's Avatar
So a weak battery will read higher voltage from the alt?
Old Jul 2, 2006 | 09:31 AM
CamaroBoy96Z28's Avatar
If working properly, yes. A weak battery isnt holding a charge as well as it should so the alt will compensate.
Old Jul 2, 2006 | 09:40 AM
hey01's Avatar
cool
well that rules out my battery cause im getting LOW voltage.
and unless im moving around 2000+ RPMs my gauge jiggles around a little TOO much.
my voltage regulator might be on its way.
does anyoone know of a better then stock replacement.
Old Jul 2, 2006 | 11:11 AM
Are you reading the voltage with a meter or relying on the gauge? The gauge almost always reads low.
Old Jul 2, 2006 | 05:58 PM
hey01's Avatar
the only other way i read the voltage was on freescan when i happend to have it plugged up.
i'll get the meter out tomarrow when i have someone else around to sit in the car
Red97LT1
Mar 1, 2015 05:08 PM
Gtpguy
Jan 26, 2015 04:50 PM
Hurin
Dec 13, 2014 07:38 PM
pete53
Dec 9, 2014 07:31 AM
JSK333
Sep 9, 2002 10:33 PM
