Ltcc Install Help Needed
Old Jul 2, 2006 | 01:39 PM
spcearle's Avatar
The Stickers That Mark Coil Wires Fell Off My Ltcc That I Have And Was Wondering Which Plug Is For Which Coil
I Have Plugs With The Following Wires
Purple/white
Green/white
Blue/white
Red/white
Also Which Wires Do I Tap Into On My Car For The 2 Pink 1 White And 1 Yellow Wire
My Car Is A 96
Old Jul 2, 2006 | 03:06 PM
BIG SHAFE's Avatar
Re: Ltcc Install Help Needed
Purple/white
Green/white
Blue/white
Red/white
My Car Is A 96
For the pink wire, I spliced it with the pink wire from the stock ignition coil harness.
The other wires you listed, are you talking about the wires that plug into the new coils?
Old Jul 2, 2006 | 04:58 PM
spcearle's Avatar
Yes All The Harnesses That Plug Into The Coils On Pass Bank"2.4.6.8"are Missing The Tags So I Need To Know Which Is Which....also What About The White And Yellow And There Are 2 Pink Do They Both Link Together
Old Jul 2, 2006 | 05:25 PM
BIG SHAFE's Avatar
Ok, the two pink from the LTCC I twisted together then butt connected with the pink from the ignition coil.
The yellow is for nitrous timing retard, if you aren't running nitrous just tape it up out the way.
The white wire from the LTCC I butt connected to the yellow wire from the module (mine is a '96).
Coil #2, 3 wire colors: gray, pink, red.
Coil#4, 3 wire colors: pink, green, brown(looks brownish).
Coil#6, 3 wire colors: red, blue, brown(looks brownish).
Hope this helps.
Old Jul 2, 2006 | 06:28 PM
spcearle's Avatar
that helps alot thank you
Old Jul 2, 2006 | 06:59 PM
BIG SHAFE's Avatar
Sure, let me know how it feels when its done. I love mine.
mikey4play
Mar 15, 2015 11:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
