alternator, eletrical fans, battery issues 94 z28
Old Dec 14, 2013 | 09:11 AM
  #16
Re: alternator, eletrical fans, battery issues 94 z28
I highly recommend you test at this location (as I mentioned in post #12) before going further.
Lack of troubleshooting can often only make the situation worse.
Old Dec 16, 2013 | 07:07 PM
  #17
Jake500g's Avatar
ok. I have a 680 ohm resistor. if this current work what should I do next?
Old Dec 16, 2013 | 10:14 PM
  #18
Everything you need to know has already been provided in this thread.
Unplug the VATS connection to the key cylinder under the dash and connect one leg of the resistor the purple/white wire and the other leg of the resistor to the black/white wire. You can leave the connector on and make connection that way for now to see if it works. Then you can worry on a more permanent fix.
Gtpguy
Jan 26, 2015 04:50 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
