Alright, how bad are Fram filters?
Old Feb 7, 2004 | 07:53 PM
scoobysnax83's Avatar
Well, figures that Autozone is out of Mobil 1 filters so I grab the next prettiest one. Are Fram's really that bad? And, yes its the one with the rubber grip.
Please don't respond with only Fram sucks. Tell me why they suck
Old Feb 7, 2004 | 08:26 PM
dreamer1q's Avatar
I use to run a quick lube, and heard all the oil reps spout off about thier products. I personally choose Fram filters and Castrol Sythetic oil. They stood out the best on the actual facts sheets years ago when I read them. So I stick with what I knew then. Never had any problems
Q
Old Feb 7, 2004 | 08:45 PM
jkipp84's Avatar
This is just one of the many sites out there that have dissected filters and compared. The findings are almost always the same: poor construction, bad flow, low quality materials, etc..
Old Feb 7, 2004 | 09:00 PM
AsianSensation's Avatar
Using Fram just 1 time till your next oil change to Mobil 1 will not cause any engine damge. I guarantee it.
Old Feb 7, 2004 | 10:05 PM
Robs97Z28's Avatar
here is a independent oil filter test. Check out the results and make up your own mind....
http://theoildrop.server101.com/cgi...ic;f=6;t=001279
Old Feb 7, 2004 | 10:29 PM
bdc95ta's Avatar
I was going to post about this a couple of weeks ago but forgot. yeah I recently tried to get a moble 1 oil filter for are cars, I went to 3 diff. stores, till one of them finally told me they had discontenued the filter I was like what the heck am I going to use now so I tried the K&N. Wonder if it's worth the $12!!
Old Feb 7, 2004 | 10:55 PM
dnz28's Avatar
I have ran frame for years, no problems.
Old Feb 7, 2004 | 11:25 PM
InjectedSS's Avatar
Re: Alright, how bad are Fram filters?
Well get the K&N filter then if you need a substitute. Personally the M1 filter is MY SUBSTITUTE for the K&N I normally get
Old Feb 8, 2004 | 12:22 AM
S.J.S.'s Avatar
12 bucks for the K&N???? You gotta be kidding me. Hell, that would mean 45 bones every 3 months. HEOOOOO NO. Think I'll try the Double Guard then.
As for Castrol Syntec.......not to pound on them but I ran that in my car after I got it back in 97. With 79k on the clock I spun 3 of my rod bearings, 2 of which were heavy. My motor was a screamer too. Bone stock out of the show room with 3500 miles on it I pulled a 14.1. I thought the motor was great. Ohhh well.
Old Feb 8, 2004 | 02:28 AM
bdc95ta's Avatar
where do u get 45bucks +5 qts. of oil??
Old Feb 8, 2004 | 02:32 AM
S.J.S.'s Avatar
Well....hmmmm....let me see. Mobil 1 here is 5 bucks a quart, x6 is 30, plus 12 bucks for the filter. Okay my bad 43.00.
I don't recall typing 45 bucks+5 qts. of oil.
Old Feb 8, 2004 | 04:53 AM
Compstall's Avatar
IMO, as long as you at least CHANGE your oil and filter on a regular basis, regardless of brand, you'll be just fine.
I know a guy that owns (2nd owner since I had it) a car I once owned. I sold it 4 years ago with 119k on it. It's got 270k on it now and still runs like a top, and I used nothing other than a plain old Fram filter and Q-state 10w40.
Old Feb 8, 2004 | 09:35 AM
Eliminator's Avatar
That is a interesting site for better understanding of oil filters its always good to know whats out there.
Old Feb 8, 2004 | 09:46 AM
1fast95Z's Avatar
I've been using Fram and Mobile 1 for decades. Never had a problem. Something to consider is that it is not necessarily the dirt in the oil that causes issues. It's the metal shavings that cause the wear. I stick a big magnet (pulled out of a huge scsi hard drive) on the bottom of my oil filter. It will catch and hold the shavings making your oil cleaner and your filter more efficient.
Old Feb 8, 2004 | 11:03 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i had a 98 plymouth breeze. i changed the oil religously at 3333, 6666, 9999, 13333, 16666, .... you get the idea. i was the original owner and sold it at 85000 miles. i used valvoline 10-40 and a fram double guard on every change. of course it was not a high performance engine but it saw its share of 5000 rpm. the oil came out very clean at every change. you could see through the stream as it was filling the oil pan. i agree with compstall - as long as you chage regularly it wont matter what brand you use. that being said - i use a mobil 1 and full synthetic valvoline on the lt1 every time.
david
