Airbag sensor comes on??
Old Oct 19, 2003 | 01:53 AM
NewbieWar's Avatar
sometimes the airbag sensor comes on what the hell does it mean... when i first got it i as hoping it didnt explode while i was driving, but why does it stay on? it usually blinks 5 times when car gets started then goes off
Old Oct 19, 2003 | 04:45 AM
Zeueses 97 RamAir's Avatar
console
ur module is bad it should blink 7 times if srs system works correctly, ok listen up where the e brake is u take the console apart in the middle where the e brake is at the module is there unplug it, get another.....
Old Oct 19, 2003 | 09:17 AM
A loose connection can make the light stay on. Usually when the light is on, the system is disabled.
Old Oct 19, 2003 | 01:09 PM
NewbieWar's Avatar
but its not on all the time, its usually on when i just turn it on jam it in gear and go... but when i wait a sec it'll go away
just wonderin why
Old Oct 19, 2003 | 05:27 PM
WhiteBeast's Avatar
Check the connectors under dash. There will be one behind the glove compartment that is all in yellow and one that is under the steering wheel dash.
Same thing happened to me and it was just a loose connector.
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
240ssLs3
Jul 13, 2015 05:06 PM
