Airbag sensor comes on??
sometimes the airbag sensor comes on what the hell does it mean... when i first got it i as hoping it didnt explode while i was driving, but why does it stay on? it usually blinks 5 times when car gets started then goes off
console
ur module is bad it should blink 7 times if srs system works correctly, ok listen up where the e brake is u take the console apart in the middle where the e brake is at the module is there unplug it, get another.....
Check the connectors under dash. There will be one behind the glove compartment that is all in yellow and one that is under the steering wheel dash.
Same thing happened to me and it was just a loose connector.
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
