air scoop
Old Sep 12, 2003 | 09:39 PM
hot936spd's Avatar
air scoop
does it really increase hp any? or what, ive heard so many differences, would it be more likely to suck in more water?
Old Sep 12, 2003 | 11:27 PM
JoeliusZ28's Avatar
Over the stock setup its probably at least a 5-10 hp gain. I would like to know how they waterproof those things though
Old Sep 13, 2003 | 12:22 AM
Bud M's Avatar
You are talking about a scoop under the car for a CAI, right?
5-10 hp? Probably not. A few hp at higher speeds, maybe.
I have never had any problems related to water but I made a block off plate that I put on in the winter and remove in the spring.
Pics in my sig.
Old Sep 13, 2003 | 01:18 AM
NewbieWar's Avatar
my friend's friend had like a mitsubishi lancer or something, and put a cold air intake on it, and it sucked up some water and broke the entire engine, it broke a rod or somethin like that (and he got it fixed under warrenty lucky bastard)
Old Sep 13, 2003 | 02:30 AM
S.J.S.'s Avatar
I dont see how water would break the motor unless someone threw a bucket down it. I used to do this and I learned it from a few people. Actually put a lil water in the carb while gunnin the engine to clear out carbon build up. Don't know if it actually worked but I can tell you it never hurt. My dad still has his 79 pickup with the same motor and 220K miles on it. So I dont think that intake could suck up enough water to hurt it. For petes sake when I raced dirt bikes I used to submerge my trail bike without problems. Just make sure the filter is preoiled well.
As for the HP gain......I'd like to know myself.
Where do you get them from anyway?????
Old Sep 13, 2003 | 03:50 AM
MentalCaseOne's Avatar
thats a hard question to answer.... size of the scoop, speed of movin air into the scoop... Air being utilized by the engine... type of air intake (cold air? OEM?)... how well sealed is the air forced into the Airbox is... etc etc
one thing is fer sure... if you can push more air in the scoop than the air thats being utilized then there will be some aditional horsepower made.... just by helping to pump more air into the cylinders but then again... if your car is using 300 cubic feet of air per second... can you pump say 500??? and if you do... it wont all go in, it just gunna create a pressure differential and help the car inhale more air..
How much?? is really hard to tell.
Marvin
Old Sep 13, 2003 | 05:06 AM
revtime's Avatar
It is hard to tell.
I have a dryer duct ram air scoop that I made myself just to get some more air directed to the filter.
I think it helps but I take alot of crap for having that dryer duct hangin down there.
Old Sep 13, 2003 | 06:30 AM
S.J.S.'s Avatar
someone should take their car to the track without it then install one to see if it actually helps.
I just might do that after I put my motor in and break it in. That will take a couple of months probably.
Hey MENTOCASE.........where you from?
Old Sep 13, 2003 | 06:33 AM
revtime's Avatar
Its only one bolt to remove mine so just might see whats up next week at the track.
CobraEatr
Jul 24, 2004 11:37 AM
RedLineRev
Jan 23, 2003 03:51 PM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
