Air locked
Old Sep 2, 2011 | 06:42 PM
chris79792000's Avatar
Air locked
Justgot my optispark installed today. Got everything buttoned up, topped off all fluids. I started it up, ran great, however after it warmed up it started boiling out of the overflow. I use the bleeder on the line that comes from the thermostat housing. It did have some air come out and then a steady stream of water so I thought all the air was out. I have even tried to run it with the cap off to try and flush out the air to no avail. Everytime once it starts to boil out of the overflow if I hit the bleeder antifreeze comes out. If I shut the engine off air will then come out, alot of it. I suspect this is from the heat that has built up. Do you guys have a quick and easy solution for ridding the engine of the all the air? Thanks, Chris
Old Sep 2, 2011 | 07:35 PM
Re: Air locked
If you use the proper fill procedure, there is little air to bleed out. Did you have any of the radiator hoses off when you did the work? Sometimes people reverse the bleed hose and the hose to the remote reservoir. That can cause pressure at the reservoir.
Old Sep 2, 2011 | 07:53 PM
Re: Air locked
Yeah had water pump off and radiator out. Now having a heck of a time getting air out.
Old Sep 2, 2011 | 09:53 PM
Re: Air locked
So, did you check the hoses I mentioned?
Old Sep 3, 2011 | 01:40 PM
Re: Air locked
Yeah, they were correct. I finally got it I think. I have one of the prestone backflushing kits on and I just backflushed the whole system. The only bad thing is I just lost all my antifreeze. however I got the air out I'll just add antifreeze later.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
