air fuel guage
Old Apr 17, 2004 | 12:05 AM
camaro79323's Avatar
air fuel guage
where does the purple wire from the guage hook up too?
tia oscar
Old Apr 17, 2004 | 02:02 AM
KyleBlue85Iroc-Z's Avatar
It goes to the wire coming from the oxygen sensor so it can show you the reading from it. I tapped mine into a wire coming out of the back of the computer. I can't remember exactly which one, but do a search on here for them and see if you can find it. There's a tech. page that tells you all about the wires.
Old Apr 17, 2004 | 03:08 AM
LimitedEd1LE's Avatar
The purple wire from the gauge can be tapped into the purple wire coming out of the back of the computer. You can find this wire in the bundle of wires that lead to the back of the computer. Just splice into that wire.
Old Apr 17, 2004 | 01:42 PM
thanks guys. ill look for it coming out of the computer and hope there is only one. lol
tia oscar
Old Apr 17, 2004 | 02:58 PM
NuMbNuTs670's Avatar
doing that, will it give the readings from both O2 sensors?
Old Apr 17, 2004 | 03:16 PM
schpenxel's Avatar
Shouldn't...there should be a seperate wire for each O2 sensor, its best to hook a nice switch up so you can switch between both banks, but not a whole lot of poeple do that.
Carson
Old Apr 17, 2004 | 05:00 PM
The left O2 sensor signal wire is purple/white, and connects to pin C20 (gray connector).
The right O2 sensor signal wire is purple, and connects to pin C8.
You can tap into either wire anywhere between the Os sensor connector and the PCM. Do not connect it to the wire that is part of the sensor.
Obviously, if you hook it to one sensor you only see 1/2 of the engine. To be able to select both sides, run the wire from each side to the outside connections on a single-pole/double-throw (SPDT) switch, and the center pin from the switch to the gauge. You can watch either side.
When you are all done, you will probably be disappointed in the results, unless you are into psychedelic light shows. In closed loop at idle and part load, the gauge is simply going to be swinging rapidly back and forth from lean to rich. It will only show a steady reading in open loop at startup, or at WOT. And since the stock O2 sensors aren't really very accurate at the relatively rich A/F ratios you need to make max power/torque, the readings on the gauge will tell you little more than that the sensors are working.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97ss1826
Mar 13, 2003 11:58 AM
Burn_Out
Aug 18, 2002 08:49 AM
