Aha!!! FOUND IT!!!!
Aha!!! FOUND IT!!!!
Foudn the reason why my perfomrance is dropping off....
#1. Crappy leak from Intake manifold
Take care of it later durring Cam swap...
#2. Coil is Sh!tty!!! Car no like starty!
Not sure if I killed it because I was using the stock wires at the time after having the Taylors scew up... but I have 8mm's on there now. I think the manual called for 8 and above or something... screw it... Should I go MSD again... or is there a better company out there that makes a good Blaster... or for the 6AL am I stick with the MSD Blaster... 2 years and it's f34ked...
#3. My rear driverside spark plug and wire are boggin in and out. I think I stripped or cross threaded something installing it...any ideas on how to fix?
Finally where getting somewhere...
Nayr
Mar 3, 2023 08:34 PM
