Aha!!! FOUND IT!!!!
Old May 24, 2004 | 06:23 PM
Heatmaker's Avatar
Advanced Member
Aha!!! FOUND IT!!!!
Foudn the reason why my perfomrance is dropping off....
#1. Crappy leak from Intake manifold
Take care of it later durring Cam swap...
#2. Coil is Sh!tty!!! Car no like starty!
Not sure if I killed it because I was using the stock wires at the time after having the Taylors scew up... but I have 8mm's on there now. I think the manual called for 8 and above or something... screw it... Should I go MSD again... or is there a better company out there that makes a good Blaster... or for the 6AL am I stick with the MSD Blaster... 2 years and it's f34ked...
#3. My rear driverside spark plug and wire are boggin in and out. I think I stripped or cross threaded something installing it...any ideas on how to fix?
Finally where getting somewhere...
Old May 25, 2004 | 10:21 AM
Heatmaker's Avatar
Advanced Member
Old May 25, 2004 | 10:42 AM
Valkyn71's Avatar
looks like your going to have to Helicoil it, not sure exactly how its done.
Worst case you will have to pull the head and take it to a machine shop
Old May 25, 2004 | 03:03 PM
Heatmaker's Avatar
Advanced Member
That blows...
On another note... If my Heads have to come off...dang sure some STage 2's LT-4s are going to replace them...
Nayr
Mar 3, 2023 08:34 PM
marlar98
Sep 12, 2018 07:18 AM
Jeff1904
Jun 5, 2016 05:00 PM
Double aught
Oct 2, 2015 11:29 PM
rideordie
Sep 7, 2015 08:22 AM
