Aftermarket Hub and wheel install
Old Jul 10, 2003 | 01:04 AM
Ponykillr's Avatar
I took the wheel off and airbag module but the Momo hub will not fit in the steering colum. do I have to drimmle some of the plastic away to get it to go on?
Old Jul 10, 2003 | 01:30 PM
Ponykillr's Avatar
Ok ill be working on this problem today about to go hit it with the Drimmel. Why does every job I do on my car involve my Drimmel???? Also my Drimmel is starting to make noises this will be the second one to give out on me cause of my pos car.
Old Jul 10, 2003 | 01:43 PM
Helpful hint... since this is a continuation of your thread "How to remove steering wheel", why not just continue the topic in that thread, rather than starting a new one. Too many threads on the same subject by the same person pushes other peoples' threads off the bottom of the page even faster.
Also, posting your own response to push your threads to the top of the list every few minutes it not acceptable either. "TTT" is discouraged when used more than once per day.
Just a couple thoughts.
Old Jul 10, 2003 | 02:35 PM
Ponykillr's Avatar
My first thread was about taking the wheel off which i did no its a new problem gettting the new hub on. My last thread kinda went off on its own different way so I started a new one about the current problem. also not to be a **** but the last time I responded to this thread was one day I posted waited a day then moved it to the top without using the stupid TTT. If you look at the post times you will notice an AM PM difference. Also im still working on the car and cant get it to work so If anyone has some helpfull hints in the Automotive department let me know.
Chevyguy358
Jan 28, 2015 08:04 PM
Collector Car
Jan 5, 2015 10:58 AM
hotrodyou1
Dec 20, 2014 10:05 PM
Noenav
Dec 6, 2014 07:35 PM
