Aeromotive Regulator Setting?
Old Oct 17, 2004 | 08:06 PM
JOE96Z28SS's Avatar
I have the 25 lb/HR LS1 Take off injectors. What Fuel Pressure should I set my Regulator to to make sure the Flow Rating is Correct??
Old Oct 17, 2004 | 11:19 PM
Re: Aeromotive Regulator Setting?
Apears those are the LS1 28.8# injectors (rated at 58psi), which have been re-rated to 25# based on the LT1's stock 43.5psi fuel pressure. First, confirm this with the person you bought them from. Then set it to 43.5psi, without the vacuum line connected.
Old Oct 18, 2004 | 12:20 AM
JOE96Z28SS's Avatar
I Bought them from SLP So I guess their Supposed to be 43.5, But I did'nt know to adjust with line Disconnected, Thanks
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jan 23, 2015 01:13 PM
