Getting Heads ported... Couple of ?'s
Old Oct 17, 2004 | 11:09 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Ok so I blew a head gasket and now I am getting my heads ported. I'm getting a full port done to them by a reputable local shop... Here is my question. Should i have the intake manifold gasket matched?? They said they would charge 150 for it, I HAVE the money if i need to... Should I? Is it worth it? Also, should i get the stock lifters replaced by a good set of Comp R's? THanks guys.
Chris
Old Oct 17, 2004 | 11:12 PM
Z95m6's Avatar
Re: Getting Heads ported... Couple of ?'s
What cam are you running? if you are running a XE cam larger than 224/230 or a cam with lots of lift like the CC306 i would get Comp R's. Don't waste your money on the intake porting. Do a search. Many of the Pro's say its not worth the time or money.
Old Oct 17, 2004 | 11:18 PM
turbo_Z's Avatar
I guess its worth the money if they do the work correctly. I was told the gains arent made from gasket matching anything.. heads or intake. So if they tell you all thats getting done is some gasket matching then save you cash.
Old Oct 17, 2004 | 11:21 PM
I have a hotcam but i am getting alot of ticking from driver side RR and people have told me it sounds like a lifter not pumping up all the way... but i dunno. So most people dont port their intake manifold??
Old Oct 17, 2004 | 11:45 PM
Z95m6's Avatar
In my experience with lt1's, we've never had issues making 480-500hp NA with the stock manifold, which is a fair amount over the "400rwhp" everyone always wants with manual cars. Even trying to make more than 500hp, a simple well ported manifold is all I'd ever do in most cases. With some of the #'s I've seen race setups make with these manifolds, I'm not 100% convinced theyre a huge bottle neck. We'll know soon enough however, as we've got some higher hp packages going together now that should push it, and since we're doing them instead of customers we'll be able to monitor all of our test conditions & know for sure whats going on
That was posted by Phil at Advanced Induction in a post on here.
Old Oct 18, 2004 | 12:00 AM
rpm4lalo's Avatar
I ported mine but I am well past the 500hp mark. Save your money.
Old Oct 18, 2004 | 01:17 AM
Thanks guys, im sure i can find a good place for the 150 bucks other than the intake manifold port. Thanks guys. I think i am gonna spend that money on new lifters.
StansZ28
Feb 19, 2015 07:39 AM
Roadie
Feb 16, 2015 10:34 AM
squarehead
Jan 15, 2015 07:02 PM
NewsBot
Dec 28, 2014 06:20 PM
