Aeroforce Scan Guage is not giving me a IAC reading.
Old Aug 9, 2009 | 06:57 PM
djm_e22's Avatar
I'm trying to solve my idle problem so does the Aeroforce Scan Gauge not have the ability to read what the IAC is doing on LT1's? Example: When I am on retard and if it reads 0.9 then I switch to IAC it just reads the same thing 0.9. Anybody try to get a reading from your IAC with the Aeroforce Scan Gauge?
Old Aug 9, 2009 | 09:29 PM
That Camaro Guy's Avatar
I've never heard of one of those. I mounted a scanmaster into my dash, it's never given me a problem. IAC should read in whole numbers, or counts from 0-140 or something like that. If it's reading 0.9 then I would assume your scanner is having trouble.
Old Aug 9, 2009 | 10:40 PM
djm_e22's Avatar
Its not actually reading 0.9 for the IAC counts, its just simply not changing from the previous reading I got from the retard. Did your scanmaster give you IAC readings?
Old Aug 10, 2009 | 12:09 AM
Yes, the ScanMaster provides IAC readings.
Just curious... when you see you have knock retard, why do you want to suddenly look at the IAC counts?
Old Aug 10, 2009 | 09:00 AM
djm_e22's Avatar
It's not just retard. If I switch from throttle voltage which might read 0.52, then have set to cycle to IAC after it will read 0.52. I guess I should start the cycle to read IAC first to see what it does.
rocknroler69
Parts Wanted
Jul 19, 2015 08:45 PM
Zuvell
May 15, 2015 08:18 PM
ad356
Apr 22, 2015 08:35 PM
lt1matt
Mar 21, 2015 07:35 PM
grgguy
17
Feb 23, 2015 07:57 PM
