advice on y pipe to catback connection
Old Apr 25, 2006 | 01:07 PM
bringBackCamaro's Avatar
Nomatter how much I search the forum I cannot find a direct answer on this
If you connect a Pacesetter Y pipe to a 3" catback
How are you holding this together?
Is the Y made slide over the I pipe without modification? Vise Versa?
Expand the I pipe, and use steped band clamp?
Butt them together and use a butt band clamp?
Old Apr 25, 2006 | 03:50 PM
2000GTP's Avatar
Re: advice on y pipe to catback connection
I have the Magnaflow catback and the intermediate pipe was slightly oversized so it slipped right over the end of the Pacesetter y-pipe. I then sealed it up with a 3" band clamp.
Old Apr 25, 2006 | 04:08 PM
raxxus's Avatar
This is the only part that pissed me off all to @%#$ when I installed my pacesetter longtubes. The ORY was 3" and my catback (hooker cat back ) was 3" ( note: they do not "slide" into each other, despite the assurances from the reps. at pacesetter ). I ended up taking off the catback and took it to an exhaust shop, and they cut it down and clamped it to the ORY after welding a slightly bigger adapter to the catback. Good luck!
Old Apr 25, 2006 | 04:44 PM
2000GTP's Avatar
I was prepared to do what you had to... I was very surprised when the I-pipe just slid over the y-pipe. That was the only part of the header install that went well!
Old Apr 25, 2006 | 05:14 PM
1quickTA's Avatar
I had to expand a pipe (I think it was the y-pipe actually) and used a stepped band clamp.
Old Apr 25, 2006 | 06:34 PM
LJ93Z28GM's Avatar
3" Ball and Socket flange so that you can break it down if you have to work on anything. Makes life nice and also allows for some adjustability.
Russ95Z28
Apr 23, 2015 01:55 PM
96 TA
Sep 1, 2002 02:48 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
