advice, on parts thnx...
Old Aug 22, 2006 | 08:31 PM
JIZZO's Avatar
97 camaro z, with pro carger if 50 state, or vortech, wit maybe around 8-12 boost. slp shortie headers, cut out, lt4 conversion kit 30 lbs injectors, i need help about pickin a good pair of heads, and also about my transmission, wat kind of shifter should i use(automatic), torque converter, gear? also how hard would it b to convert mah ride to a T56, noe how much i would end up spending?
THNX
Old Aug 22, 2006 | 08:32 PM
JIZZO's Avatar
Re: advice, on parts thnx...
Im In California...
Old Aug 23, 2006 | 01:49 PM
For info on the A4-> M6 conversion, do a "search" on the "Drivetrain" forum.
The rest of your question isn't very clear. Appears you already have:
-slp shortie headers
-cut out
-lt4 conversion kit
-30 lbs injectors
Is this correct?
Then you appear to be considering the addition of either an ATI ProCharger or a Vortech, and running 8-12# of boost. Hopefully, not on a stock block.
Is this correct?
Then you want to select a good set of heads for the above combination? If you have the LT4 Conversion Kit, you alread have heads that would work with the rest of your parts and the blower. And you are looking at a torque converter, shifter, and new gears?
Not sure I understand the question.
cmyname1
Feb 16, 2015 08:33 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
ModdedNerd
Dec 10, 2014 08:42 PM
