Advice Needed
Old Apr 18, 2011 | 06:53 PM
my1994z28's Avatar
Advice Needed
I need some advice as to what lb injectors I should run in my lt1....020 over,cnc ported stock heads,edelbrock intake full ported,comp cam 242 intake and 252 exhaust @.050,comp 1.6 rrs,pacesetter lts,borla exhaust,4l60e trans w/3500 stall,3.73 gears,walbro 255...The will be going to be dynoed in the next few weeks and I need to order some injectors before then..
Old Apr 18, 2011 | 07:17 PM
Transporter9033's Avatar
Re: Advice Needed
36#'s should be plenty good for what all you have listed there.
Just make sure you get a good brand. No Accel or Venom.
Old Apr 18, 2011 | 07:21 PM
bw_hunter's Avatar
Re: Advice Needed
What was your hp target when you bought that cam? I can't guess what your output will be so I'd always go bigger....42#/hr will support much more power than you're likely to make snd the PCM can adjust to compensate if they're oversized...
Old Apr 18, 2011 | 07:25 PM
RamAir95TA's Avatar
Re: Advice Needed
I like Fred's formula. Take your estimated flywheel HP and multiply it by .07 to get your suggested injector sizing using a BSFC of .5.
FWIW, I have 42# injectors with a MUCH smaller cam and they see peak DC around 70%, so I'm thinking 36#s might be a bit on the small side.
Old Apr 18, 2011 | 07:30 PM
my1994z28's Avatar
Re: Advice Needed
Target rwhp was 425..that was before i changed from a 6spd to a 4l60e..After 5 failed back surgerys and nerve damage to my left side,I decided to keep the car a make it an auto.I was running a spec 3 clutch at the time,I could have probably gone with a less aggresive clutch and been ok..live and learn.
Old Apr 18, 2011 | 07:57 PM
bw_hunter's Avatar
Re: Advice Needed
If that's the case, 38's will work. I'd still go with 42's just to be on the safe side.....
Old Apr 18, 2011 | 08:22 PM
my1994z28's Avatar
Re: Advice Needed
Would 42lb Red Tops be a good choice?
Old Apr 19, 2011 | 05:17 AM
Re: Advice Needed
You have to use flywheel HP to determine the required injector size, not rwHP. The 0.07 factor suggested above results in the minimum recommended size, and is based on a BSFC of 0.476 #/HR/HP and an 85% maximum duty cycle.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
1775.Z28
Jan 11, 2015 10:51 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
