Advanced Header question. Feel free to read but please don't reply with useless info
I pulled my Pass side header today. I noticed the number 2 primary (first on right side) had some black around the flange but the rest of the pipe was real clean compaired to the other 3 primaries. The # 4 was not as dirty as 6 or 8 but it was not as clean as #2.
Im wondering if it is possible to have a cylinder not firing properly? How would I check for this and what could be the cause. Fuel or spark, correct. IE Plug or wire or fuel injector?
When I pulled my plugs most of the had a yellowish color to them. This indicates that they are getting heated up fast under acceleration. Correct? What would I do to fix this? Colder plug, more gap less gap?
What else could I look at to see if I have a miss? Tomorrow I plane on looking at the top of the cyl threw the plug hole. I asl want to do a compression ck on all 8 cyl to se what Im running.
Also how much can you port the Hooker LT's? I see a lot of places where exhaust is hitting the flange or gasket rather than going down the primary.
JasonD
Jul 15, 2002 02:17 PM
