Advanced Header question. Feel free to read but please don't reply with useless info
Old May 15, 2004 | 07:23 PM
supermo26's Avatar
Question Advanced Header question. Feel free to read but please don't reply with useless info
I pulled my Pass side header today. I noticed the number 2 primary (first on right side) had some black around the flange but the rest of the pipe was real clean compaired to the other 3 primaries. The # 4 was not as dirty as 6 or 8 but it was not as clean as #2.
Im wondering if it is possible to have a cylinder not firing properly? How would I check for this and what could be the cause. Fuel or spark, correct. IE Plug or wire or fuel injector?
When I pulled my plugs most of the had a yellowish color to them. This indicates that they are getting heated up fast under acceleration. Correct? What would I do to fix this? Colder plug, more gap less gap?
What else could I look at to see if I have a miss? Tomorrow I plane on looking at the top of the cyl threw the plug hole. I asl want to do a compression ck on all 8 cyl to se what Im running.
Also how much can you port the Hooker LT's? I see a lot of places where exhaust is hitting the flange or gasket rather than going down the primary.
Old May 15, 2004 | 07:45 PM
supermo26's Avatar
Kmook thanks for the PM's How do I post my AF ratio graphs on the board?
Kataklysm's Avatar
Black around the flange means its leaking, thats all the info I can give.
Old May 15, 2004 | 07:51 PM
supermo26's Avatar
Only the inner side of the flange is black where the heads are ported wider than the headers. The gaskets apear to have a indented seal from the torque of header bolts.
Old May 15, 2004 | 08:00 PM
Kataklysm's Avatar
Whats the tube size on the headers?
Old May 15, 2004 | 08:05 PM
supermo26's Avatar
Hooker LT Primary are 1 3/4 primary. 3 inch collector.
Can anyone look at my AF ration graph and tell me what they think?
How do I post the pictures?
Old May 15, 2004 | 10:09 PM
Fastbird93's Avatar
Send me your A/F graph and I'll take a look.
Old May 16, 2004 | 12:24 AM
Gripenfelter's Avatar
I'd guess either a header gasket leak or a valve rocker too tight.
Old May 16, 2004 | 01:43 AM
supermo26's Avatar
What do you think about dynoing 403.3 HP with 383 AFR 210 Heads and Comp 236 242 112 LSA cam with all bolt on and valve train work? Im thinking Im missing some HP some where
Old May 18, 2004 | 09:47 PM
supermo26's Avatar
I thinking of going to a 4 inch stright threw muffler and I pipe set up. What do you think? Too much?
willismoons
Feb 14, 2015 08:42 PM
Kyle@SLP
Jan 7, 2015 02:09 PM
Thebeast431
Aug 8, 2002 01:39 PM
JasonD
Jul 15, 2002 02:17 PM
Brent94Z
Mar 21, 2002 04:44 PM
