383 cam help
Old May 18, 2004 | 12:09 PM
1984camaroz28's Avatar
383 cam help
whould would be a good cam for...
383
11 to 1
trick flow heads
and a 150 shot of n2o
I was told the cc306 then told not to go with it
Old May 18, 2004 | 12:25 PM
SStrokerAce's Avatar
Are you going to have the heads ported?
What's the rest of your mods?
Tranny?
Gear?
Stall/launch?
Use? Driver or strip car?
Those things help too.
Bret
Old May 18, 2004 | 12:31 PM
if i can find someone to port them around me yes.
trany : t56
Gears : 4:10
launch: dont no yet
The car is not an every day driver. it a weekend car i just got out and screw around and go to the track
Old May 18, 2004 | 02:37 PM
formula383's Avatar
I had the CC306 in my old Formula and I was very happy with it. However the best bet would probably be to find out what the heads flow and get a cam custom grind for it.
Old May 18, 2004 | 04:23 PM
WS Sick's Avatar
There is a cc nitrous specific cam that is a little like the CC230/236 but has a wider lobe seperation and I beleive with a 110 degree intake centerline, its specs are.
224/236 503/521 (w 1.5s) 114 lobe sep. this thing is slightly mild driving around (about like a 230/236 CC)
Old May 18, 2004 | 04:50 PM
magnumv8's Avatar
you really need to have some flow numbers for your heads before you can properly match a cam to your setup.
Why not just port your stock heads instead of buying Trick Flows and porting them?
Old May 18, 2004 | 09:52 PM
because ported trick flow heads are alot better then stock heads
Old May 18, 2004 | 09:54 PM
anyone got any flow#s on the heads stock
drptop70ss
Mar 26, 2015 01:50 AM
transam_388
Mar 15, 2015 11:53 AM
Killer94z
Jan 13, 2015 12:06 PM
Queens94z28
Nov 20, 2014 06:03 PM
