Adjusting valve lash
I know the proper sequence to adjust the valves......Im just alittle confused on how to do it. The source Im reading says full roller rockers like the lt4 used(Im using the crane gold rr) should be adjusted to zero lash then torqued to 18ft-lbs from that point. Ive always heard just go a 1/4 to 1/2 turn after zero lash. Which is correct?
Originally posted by shoebox
The LT1 does not rely on torque values for rocker arm adjustment.
2QUIK6
Jul 15, 2015 07:46 PM
