Howling In Rear
Old Mar 17, 2003 | 11:35 PM
XeonBAMF's Avatar
Howling In Rear
When I am turing i hear a howling that i belive is coming from the back (possibly the diff.) It usually occurs at about 20mph and under and it dosent do it all the time. Any thoughts as to what this might be?
Also, did GM omit rear speakers in the Bose setup or was i just jipped from the factory?
Old Mar 18, 2003 | 06:08 AM
anaik's Avatar
The 93-94 Bose system came with only 3 speakers, 2 in the front doors and 1 under the hatch. 95-96 had speakers in the rear seat area.
As for your rear end, it sounds like you need some limited slip additive. Use only GM's, others don't seem to work as well.
Old Mar 18, 2003 | 06:39 AM
IDOXLR8's Avatar
It sounds like your rear is howling. I would pull the differential cover and examine the gears. If you see nothing out of whack then fill it back up with new diff fluid. Don't forget to run posi additive with your fluid.
Old Mar 31, 2003 | 10:49 PM
XeonBAMF's Avatar
Ok, thanks for the help.
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
