Adjusting valve lash
I know the proper sequence to adjust the valves......Im just alittle confused on how to do it. The source Im reading says full roller rockers like the lt4 used(Im using the crane gold rr) should be adjusted to zero lash then torqued to 18ft-lbs from that point. Ive always heard just go a 1/4 to 1/2 turn after zero lash. Which is correct?
I believe both would be the same thing. The 1/4 to 1/2 turn is just a rule of thumb for those without a torque wrench.
I thought that might be the case....Ill know when I start the process.
The LT1 does not rely on torque values for rocker arm adjustment.
Originally posted by shoebox The LT1 does not rely on torque values for rocker arm adjustment. |
