Which Adj. Fuel Pressure Regulator should I get??
Old Apr 14, 2003 | 09:58 AM
JasonS's Avatar
I have had two aeromotive AFPR go bad on me within 500km so I am changing brands. WHo should I go with??
I can get..
1- Holley (BUt they are out of stock right now)
2- Accel
3- Hypertech
SO what would you guys recomend I get?
Thanks, Jason
Old Apr 14, 2003 | 10:01 AM
norcalstreet's Avatar
I've heard many good things about the Hypertech one.
Old Apr 14, 2003 | 11:22 AM
JasonS's Avatar
Darn the accel is $50 cheaper
Thanks.
Anyone else have any recomendations?
Old Apr 14, 2003 | 11:36 AM
95NX-TA's Avatar
They are all good brands. Choose one I have the Holley and it was supposed to be preset at 43.5 psi and it wasn't. It was set to 28 psi, and I just pumped it up and it worked fine. Any of them are good.
Nick
Old Apr 14, 2003 | 11:38 AM
toegead93's Avatar
I'm curious too. What about the Aeromotive. It offers a wider range of adjustabilty for the same price.
The Accel may just be an FPR modification kit which requires you to cut open your stock fuel pressure regulator and install the new parts to make it adjustable. It's hardly worth all the trouble it takes.
Old Apr 14, 2003 | 11:48 AM
93zder's Avatar
Anyone try the SLP unit? It's only $65!
Old Apr 14, 2003 | 11:54 AM
JasonS's Avatar
I have had 2 aeromotive ones go bad on me within 500km!! I have also read many other peoples problems with this unit!
The accel part number 74566 seem to be a complete unit not a modification kit. From what I can see any way.
Old Apr 14, 2003 | 12:46 PM
94SLUG's Avatar
Dont get AM i had one it broke in 1month. Same thimg happened to my brother. Just get a stock delco unit 59.99 the FPR is worthless due to PCM. If you set Fp to 36 it will take it back to the factory default 41.5. Dont wast more money.
Old Apr 14, 2003 | 01:12 PM
gb95zconv's Avatar
Wrong....the pcm doesnt know what your fuel pressure is and an afpr can be helpful in tuning cammed and forced induction apps that have maxed out BLMs (or close to maxed) . You can adjust the pressure to bring it back in the BLM range where the pcm can effectively control A/F. You can also use it to tune WOT to some extent also as well as open loop idle. Now I do agree that an afpr is of little use on a stock or bolt on car.
Old Apr 14, 2003 | 01:23 PM
JasonS's Avatar
I partly agree that on a stock or close to stock car a AFPR is worthles. However like said when tuning a 396 stroker supercharged Camaro like mine it is needed.
Yes the AM is junk. I have read many many things about it and how they always leak. There are also some who have had good luck with them but since I went through 2 of them within 500 mmiles I am changing brands for sure.
Old Apr 14, 2003 | 01:25 PM
JasonS's Avatar
A.R.E. has found me a Holley unit and are sending it over to me so I should have it tomorrow. I will set it to 38# (static) like they told me too and I will let you guys know how this one holds up in a couple of weeks.
Old Apr 14, 2003 | 03:37 PM
94SLUG's Avatar
How is it needed i have a 500hp sc camaro also, unless your trying to max the injectors. Where is it going to help you tune. From what i understand it does not matter what you set the AFPR to the ECM will compensate. Rich uses stocker with 743rwhp.
Old Apr 15, 2003 | 06:17 PM
gb95zconv's Avatar
Well you dont understand then....I never said it was needed ....I said it could be helpful in certain apps. There are ways to tune other than with an afpr....ie working with injector constants , offsets and fuel trims in the pcm tables as well as VE tables for SD mode. I also never said to use the stock injectors....upgrade if your maxing them. You have to look at each app a deside what method or combination of metheds you are going to use to tune with.
Like I said if your BLMs are out of range one way or the other you can use an afpr to bring then back in range.....or you can play with the fuel constant or a combination of both.
FlyboyZ28
26
Feb 9, 2003 02:39 AM
FlyboyZ28
Apr 10, 2002 04:12 PM
FlyboyZ28
Dec 10, 2001 10:30 PM
FlyboyZ28
Nov 4, 2001 07:34 PM
FlyboyZ28
Nov 4, 2001 02:00 PM
