Adapter to hook tubing together for gauges?
Old Jun 8, 2003 | 05:25 PM
SloMofo's Avatar
Question Adapter to hook tubing together for gauges?
For the way I am gonna run the line into the car for my oil press. gauge I am gonna need to hook 2 pieces of the tubing together. I looked on SUmjmit's site and didn't see an adapter to do that.
Anyone make one or perhaps someone has an idea of what I should do?
Old Jun 8, 2003 | 07:49 PM
mmmmm..... what kind of tubing... metal, plastic, braided S/S, etc????
Old Jun 9, 2003 | 08:01 AM
SloMofo's Avatar
The normal 1/8" nylon or copper tubing that goes with the autometer gauges
Old Jun 10, 2003 | 07:37 AM
SloMofo's Avatar
Old Jun 10, 2003 | 07:50 AM
OldSStroker's Avatar
If you mean 2-into-1, you could use brass compression fittings from your local home center. Try a "T", or maybe a "Y".
If you aren't familiar, the tube slips thru a small double tapered ring which is compressed into a mating taper in the fitting by the cap or nut.
There are some quick install/release plastic fittings for nylon air lines which mighy work, but they are harder to find.
Try McMaster-Carr:
http://www.mcmaster.com/
click on "Instant Tube Fittings" then page 139.
Old Jun 10, 2003 | 08:09 AM
Most places like NAPA will have compression fittings for joining the tubing.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Rich_z28
Aug 29, 2002 10:44 PM
