accurate stock LT1 in Desktop Dyno?
Old Aug 22, 2003 | 08:11 AM
magius231's Avatar
does anyone have a file for an accurate stock LT1 for Desktop Dyno 2000? I have flow numbers from stock heads, stock cam timing, and the rest should be just plug and play but it still wants to list our motors as having only 230hp (flywheel) or so...
Old Aug 24, 2003 | 10:03 AM
magius231's Avatar
TTT - anyone at all?
Old Aug 24, 2003 | 10:45 PM
m0nk's Avatar
could you do me a favor, post the stock head flows, and post the stock cam timing, and ill see if i can find out whats going on?
Old Aug 24, 2003 | 11:01 PM
madhatter's Avatar
yes me too
Old Aug 25, 2003 | 04:53 AM
magius231's Avatar
ok here are the files I am using:
http://web.infoave.net/~magius231/lt1_1996_stock.cam
http://web.infoave.net/~magius231/stock_al_lt1.flw
http://web.infoave.net/~magius231/stocklt1.dyn
loading these up you will notice that power peak is 219HP@3500RPM which is way off...
thanks guys
Old Aug 25, 2003 | 03:23 PM
m0nk's Avatar
There has to be something wrong with thos cam specs, I also ran It and it gave somewhat of the same results you have, then I changed the cam to the default stock/street economy cam and it gave me 298@4,500
Old Aug 25, 2003 | 10:42 PM
magius231's Avatar
well the cam timing came from the LT1 cam R&R site...I plugged in the values for my XE 230-236 and it still peaks at 5000RPM (with small tube headers/mufflers) Something about this doesn't seem right...I got the timing figures straight off the cam card too...I'm wondering if I am reading it wrong or something now...
Old Aug 25, 2003 | 11:14 PM
m0nk's Avatar
My dyno2003 came with a cam file from a comp cam and it says it is "best for origional LT1 with stock computers." And it comes to 296hp @ 4,500-5,000rpm and 278hp @ 5,500rpm. The valve event timing is as follows. Remember that these numbers are at optimum performance with a perfect tune, so this is likely very close to the stock cam.
seat-to-seat .050
IVO:23 -5
IVC:63 35
EVO:76 48
EVC:20 -8
InD:266 210
ExD:276 220
This leads me to belive that the IVC of 29.5 and EVC of -23.5 are off as the other valve events are close.
Old Aug 26, 2003 | 05:19 AM
magius231's Avatar
thanks, thats definitely a little better, but it still peaks at 288@4000RPM...5500RPM is making 233HP. What flow numbers for heads and whatnot are you using for that figure?
Thanks again!
Old Aug 26, 2003 | 10:53 PM
m0nk's Avatar
http://members.aol.com/atomicm0nk/images/StockLT1.jpg
http://members.aol.com/atomicm0nk/images/StockLT12.jpg
Old Aug 26, 2003 | 11:07 PM
FastZinTennessee's Avatar
Hmmm, I loaded up some specs I dug up on LT1s and got 294 hp at about 5000 RPM. I figure that's about right, desktop dyno is figuring a perfect tune, and probably no loss from turning an AC compressor etc. In my opinion the torque was waaaaaaay off, it was something like 385 ft. lbs.
The file got corrupted, so I had to reinstall it, I'll probably be playing around with it some more this week.
John
D1SC383LT4
Jan 1, 2016 01:56 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Jlo
Feb 3, 2015 09:41 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
