Accel Opti Arrived! Pics inside.
Old May 10, 2006 | 10:15 AM
  #16
thesoundandthefury's Avatar
Re: Accel Opti Arrived! Pics inside.
Maybe we should all donate $5 to a "fund," and use it to buy one of these for the purpose of cracking it open and comparing/contrasting the parts in it against the parts in a stock Opti.
Old May 10, 2006 | 11:03 AM
  #17
nodnarb481's Avatar
is it possible it could not be as good as OEM? Im not exactly looking for something better (because that would probably cost a fortune) but what are some good replacements for OEM as of now?
Old May 10, 2006 | 11:19 AM
  #18
moparman's Avatar
The MSD unit is another alternative. Apparently it has some improvements. Also more expensive.
Old May 10, 2006 | 12:51 PM
  #19
Steve0's Avatar
Besides the OEM unit, for just straitup optispark replacement, to my knowledge there is:
The Accel, the one I pictured. $299 at summit, but only $199 at JC Whitney for some odd reason. Oil lite bushings, "upgraded case" supposedly stronger than the stock unit. Not much word out there on reliability yet.
The Summit optispark which advertises the same upgrades the Accel does, and is probably the exact same unit. It sells for $249 at Summit Racing.
The MSD unit which sells somewher around $500 if I remember correctly. I believe it allows you to adjust timing 5 degrees advanced or retarded. It runs about $550.
Then there's the dyna-spark unit which has a number of upgrades and is really pricey. I have no idea what the price on one of those is right now, but I imagine its up there with MSD's unit.
Old May 10, 2006 | 12:54 PM
  #20
Steve0's Avatar
Originally Posted by Javier97Z28
If it can't take 7,000 RPM.. I don't want it
The king of optisparks, the dyna-spark is only advertised to be reliable up to 6800rpm. I doubt the Accel for 1/3rd the price can handle that kind of performance.
Old May 10, 2006 | 08:09 PM
  #21
pearlpurple's Avatar
none for 93's??? only the vented kind??
Old May 10, 2006 | 08:48 PM
  #22
blackz97's Avatar
If i remember correctly MSD is boasting 10,000 rpm for their opti spark, with a redisigned optical pickup that has the ability to go +-5 degrees on the timing. It also has a billet housing which is nice.
Steve
Old May 10, 2006 | 09:41 PM
  #23
Javier97Z28's Avatar
Moderator
Steve
If that's the case, whenever my opti goes I'll probably go for one
Old May 10, 2006 | 09:43 PM
  #24
Cmr0z28's Avatar
Originally Posted by DontMixWithRice
buy a honda.
Eat your own **** and let me know how it tastes.
Old May 10, 2006 | 10:09 PM
  #25
zbomb5610's Avatar
What an ingenius comment.... I take it you've never taken a ride in a high RPM LT1 huh? Mine will be revving proudly to 6900 RPM when finished up.
Yep, i rev mine very close to 7k and have done it several times with no problems.
Old May 10, 2006 | 10:13 PM
  #26
Z95m6's Avatar
yeah i wouldn't buy an opti with a bushing in it. I want a bearing in my opti especially for the for the price the command.
Old May 10, 2006 | 10:40 PM
  #27
NovaTodd's Avatar
Originally Posted by ssean92
how does this compare to the msd one???? accel, isnt one of the best products on the earth.
I have run nothing but ACCEL ignition parts on my Nova and other "low tech" cars for years with no problems whatsoever
Old May 11, 2006 | 12:18 AM
  #28
atljar's Avatar
We just got one in at work and put one on a customers car.
It seemed to spin more freely and smoothly than a new GM opti. Plus 1.
It had a better case. Plus 2
It was cheaper than OEM. Plus 3
The connector on it had some plastic molding in the way that had to be ground away. Not sure if it was just a one time defect, or something we should get used to. Minus 1.
Final score = Plus 2. We will be buying and using these again.
Old May 11, 2006 | 08:33 AM
  #29
WS Sick's Avatar
I agree , I rev my 383 LT1 at the track to 7000 (on factory tach) sounds like nothing else.
Old May 11, 2006 | 10:28 AM
  #30
Colin91Z's Avatar
Hearing this makes me consider the accell opti alot more than I did...I figured it would just be a gm opti with an "accell" sticker on it...
